GL-C-006P GLEDOPTO Zigbee 3.0 Smart LED Strip Controller Compatible with Hub Tuya Smartthings App 2.4G RF Remote Control Voice
GL-C-006P GLEDOPTO Zigbee 3.0 Smart LED Strip Controller Compatible with Hub Tuya SmartThings App 2.4G RF Remote Control Voice
🔴PLEASE NOTE: In order to maintain the smoothness of the maximum brightness, all lamp beads will not reach maximum brightness at the same time . When used it is usually warm white + cool white = 100% brightness, such as 100% warm white + 0% cool white, or 50% warm white + 50% cool white. Instead of 100% warm white + 100% cool white.
🔴Please kindly note that our zigbee devices(Zigbee/Plus/Pro version Products) require related zigbee gateways.
🔴 If you don't have any gateway, please buy one 2.4G RF remote control or wall switch to work with Plus/Pro Version Products.
The Remote Control and Wall Switch is 2.4G RF, only work with Plus/ Pro Version Products.(Not ZigBee)
🔴 RGBCCT controller will show 1ID in the App, easy to manage the lights.
🔴This device is only compatible with the GLEDOPTO 2.4G RF remote control and cannot be compatible with other remote controls.
🌈 With a high current of 15A, it is usually possible to connect longer LED strip lights, such as 10-20 meters. Due to the physical phenomenon of voltage drop, it is recommended not to connect more than 20 meters
🌈 Support Tuya App/SmartThings App control. Support APP smart life app control in Android/IOS Phone.(There are some compatibility issues with IK*E*A at present)
🌈 Support voice control by Alexa Echo/Google Home via SmartThings hub or Tuya Zigbee hub.
🌈 Support 2.4G RF remote control directly, without zigbee hub.
🌈 Group: Control all lights at the same time by creating same or different groups, and adding your lights into your group that you want.
🌈 16 million colors for you to choose and make your life colorful, to create a relaxing and quiet atmosphere. Such as living room, kitchen, bedroom and so on.
🌈 Sync your light with movies, music, and games, enjoy the light effect which synchronizes with the plot of the picture immediately, and experience the more delicate atmosphere lighting effect.
Q&A or more info, please contact us on line, and we will answer you in time.
Product Name:ZIGBEE 3.0 RGBCCT Strip Controller Pro 15A
Model No.:GL-C-008P(15A)
Voltage: DC12V-24V
Total Current: 15A
Current/Channel: 10A
Operating Temperature:-20-60°C
Input: 5.5x2.1mm DC Socket
1pcs* ZigBee Strip Controller
1pcs* User Manual
1pcs* 3cm Stricker
