GoControl Plug In Dimmer Module PD3000EMZ5-1
Regular price $22.99
Regular price $22.99 Sale price
Transform Any Lamp into a Smart Light with the Z-Wave GoControl Plug-in Dimmer Module
The PD300EMZ5-1 Best Smart Plug-in Lamp Module is designed to provide GoControl Plug-In Dimmer Module control to a connected dimmable lamp. The PD300EMZ5-1 module is plugged into any standard grounded AC wall outlet, and the lamp is then plugged into the module. Once connected, the lamp can be dimmed or turned on or off remotely via the Z-Wave controller. The Best Smart Plug module contains two power receptacles – one controlled and one pass-through (powered at all times) via GoControl Plug-In.
  • Model:
    PD300EMZ5-1
  • Protocol:
    Z-Wave Plus
  • Incandescent Load:
    300W maximum, 120 VAC
  • Overload protection:
  • Z-Wave Repeater Integrated:
  • Documentation:
