GoControl Z-Wave Plus Garage Door Controller, Gen5
$151.32
Adds Z-Wave functionality to garage door openers
Compatible with most sectional garage doors
Supports Z-Wave automation scenes and schedules
Includes a tilt sensor for door status updates
Customizable audio/visual safety alerts
Product Description:
The GoControl Z-Wave Plus Garage Door Controller with S2 Security enables remote Z-Wave control for most sectional garage door openers, allowing operation via Z-Wave controller, smartphone app, or existing pushbutton. Enhanced with S2 encryption, it provides secure communication and an extended Z-Wave range.
Features:
- Adds Z-Wave functionality to garage door openers.
- Compatible with most sectional garage doors.
- Supports Z-Wave automation scenes and schedules.
- Includes a tilt sensor for door status updates.
- Customizable audio/visual safety alerts.
The Controller emits safety alerts before door movement and includes a tilt sensor for real-time door status.
Installation:
- Connects to garage door openers; compatible with existing pushbuttons.
- Mountable on opener hardware or wall; includes bracket and hardware.
- Powered by a standard outlet.
The Tilt Sensor, installed atop the garage door, operates on a pre-installed battery and communicates with the controller wirelessly.
Z-Wave Plus Certification ensures advanced features for easy setup, longer battery life, faster operation, improved range, and noise immunity.
Package Includes:
- Remote Controller, Tilt Sensor, Power Supply, Mounting Bracket, and Hardware.
Note:
- Incompatible with proprietary technology openers.
- Requires a separate Z-Wave controller.
Product Specs:
| Installation Type | GD00Z-8-GC |
| Power: | 120VAC, 50/60 Hz |
| Sensor Frequency: | 345 MHz |
| Z-Wave Frequency: | 908.42 MHz |
| Wireless Range: | Up to 130 feet between the wireless controller and/or the closest Z-Wave receiver module |
| Scene | Command Class |
| Dimensions: |
| Certifications: | FCC, ETL, UL 325 |
Operators that are incompatible with Linear's GD00Z Controller include:*
- Chamberlain MyQ Models: WD962KEV, KPEV, MLEV; WD832KEV; HD 930EV, 420EV; LW500EV; PD752D, KPV
- Genie Series III Models: PowerMax 1500; TriloG 1200, 1500; IntelliG 1000, 1200
- LiftMaster MyQ Models: 8355, 8360, 8500, 8550, 8557, 8587
- Craftsman AssureLink / MyQ Models: 3043, 30437
