INKBIRD ITC-306A WIFI Dual Heating Temperature Controller Thermometer Aquarium Thermostat With 2 Probes for Fish Tank
WiFi Connectivity: Easily monitor and adjust your aquarium's temperature remotely through the INKBIRD app, compatible with 2.4GHz Wi-Fi networks
The INKBIRD ITC-306A-WIFI is a cutting-edge WiFi Aquarium Thermostat designed to provide precise temperature control for your aquatic environments. This Fish Tank Temperature Controller ensures a stable and safe habitat for your aquatic life, combining advanced features with user-friendly operation.
- WiFi Connectivity: Easily monitor and adjust your aquarium's temperature remotely through the INKBIRD app, compatible with 2.4GHz Wi-Fi networks.
- Dual Heating Control: Supports connection to two heating devices simultaneously, ensuring consistent warmth throughout your tank.
- Dual Probes for Accuracy: Equipped with two durable probes designed for wet environments, providing precise temperature readings and enhanced safety for your aquatic creatures.
- High and Low Temperature Alarms: Customizable alarms alert you to temperature fluctuations beyond your set range, preventing potential harm to your fish.
- Plug-and-Play Design: User-friendly setup allows for immediate use without complex installation procedures.
Maintaining an optimal temperature is crucial for the health of your aquatic pets. The INKBIRD ITC-306A-WIFI Aquarium Thermostat offers reliable and precise temperature management, ensuring a stable environment for various species. Its remote monitoring capability provides peace of mind, allowing you to oversee your aquarium's conditions from anywhere. The Fish Tank Temperature Controller helps prevent temperature fluctuations that could stress or harm your fish, ensuring their well-being.
Specifications
- Temperature Control Range: 20.0℃ to 35.0℃ (68.0℉ to 95.0℉)
- Temperature Measurement Range: -40℃ to 100℃ (-40℉ to 212℉)
- Display Accuracy: 0.1℃/℉ (<100℃/℉), 1℃/℉ (≥100℃/℉)
- Input Power: 100~240VAC, 50Hz/60Hz
- Maximum Output Load: 10A, 1200W (120V) / 2200W (220V)
The INKBIRD ITC-306A-WIFI is the ultimate Fish Tank Temperature Controller, ensuring a controlled and safe environment for your aquatic life. Whether you're a beginner or an experienced aquarist, this device is essential for maintaining the perfect water conditions in your aquarium.
