The Leviton Decora Smart Z-Wave Plus v2 Tamper-Resistant Outlet, Gen7 is the perfect addition to your smart home setup. This innovative outlet allows you to remotely control your plugged-in devices through your Z-Wave or smart hub, giving you the ultimate convenience and control. The tamper-resistant design ensures safety for your household, while the sleek and stylish Decora design seamlessly blends in with your home decor. This outlet also features voice control compatibility with Alexa and Google Assistant, making it the ultimate smart home accessory. Upgrade your home with the Leviton Decora Smart Z-Wave Plus v2 Tamper-Resistant Outlet, Gen7 today.
Package Includes
Smart Z-Wave Plus Outlet Single-gang Decora Screwless Wallplate
Manufacturer Part #:
ZW15R-1BW
Color:
White
Network:
Z-Wave Plus v2, 700 series
Security:
S0 or S2 Security
Dimensions:
1.5 (H) x 3 (W) x 1.125 in (D)
Ratings:
General Use: 15A – 120VAC, 50/60Hz Magnetic: 15A – 120VAC, 50/60Hz LED/CFL: 5A, 120VAC, 50/60Hz Incandescent: 1500W – 120VAC, 50/60Hz Motor: 3/4 HP – 120VAC, 50/60Hz Requires uninterrupted power, not for use in switched receptacle applications.
Operating Humidity:
0 to 90% non-condensing
Certifications:
cULus Listed, Energy Mgmt Equip. 9D34, NOM (Mexico), Z-Wave Plus CERTIFIED™, FCC Part 15 Class B, IC: 772C-LB1GC
