The Leviton Structured Media Center Compact Expansion Plastic Bracket is the perfect solution for expanding your structured media center. This sturdy bracket is designed to accommodate up to 3 expansion boards, allowing you to add more components to your network and customize your setup to your exact needs. Made from high-quality plastic, this bracket is both durable and lightweight, making it easy to install and use. With its compact design, it won't take up too much space in your media center, but it will provide ample room for expansion. Whether you're a home user or a professional installer, the Leviton Structured Media Center Compact Expansion Plastic Bracket is an essential tool for expanding your network.
