Introducing the Nutone Indoor Air Quality Smart Plug - the ultimate solution for monitoring and improving the air quality in your home. This innovative device allows you to control and monitor the air quality of any room in your home through your smartphone or tablet. With real-time data on temperature, humidity, and air quality, you can easily adjust settings to ensure optimal air quality and a healthy living environment for you and your family. The Nutone Smart Plug is easy to install and can be used in any standard electrical outlet. It also features a sleek, compact design that blends seamlessly with any home dĂŠcor. Take control of your indoor air quality with the Nutone Indoor Air Quality Smart Plug today.
Manufacturer Part #:
BIAQSP100P
UPC:
026715265343
Inputs:
120V, 60 Hz
Outputs:
120V, â 15A Resistive, 15A Inductive, ½ HP, 3A Incandescent, Dry Contact Class 2 â 24VAC, 60Hz or 12V DC, 40VA Max Load
Connectivity:
Requires a 2.4 GHz Wi-Fi network within 100 feet
Dimensions:
1.5 H x 5 W x 1.75 D inches
Operating temperature:
32 to 95°F (0 to 35°C)
Miscellaneous:
Wire terminals accept #20 AWG to #16 AWG solid or stranded wire suitable for at least 75°C. Wire terminals intended for ERV/HRV connection.
Ratings and Certifications:
RoHS and Prop. 65 compliant, Pollution Degree 2 product for household environment
