Optex Concrete Floor Bracket for Photoelectric Motion Towers
$100.95
The Optex Concrete Floor Bracket is a sturdy and reliable accessory designed for use with photoelectric motion towers. Made from high-quality materials, this bracket is specifically designed to securely hold the tower in place on concrete flooring. It features a simple and easy-to-install design, making it the perfect solution for ensuring your motion detection system remains stable and effective. Whether you're using the Optex Concrete Floor Bracket for home or commercial applications, you can count on its durability and longevity to provide many years of reliable service. So, if you want to ensure your photoelectric motion tower stays put, the Optex Concrete Floor Bracket is an essential accessory you won't want to go without.
| Manufacturer Part # | AX-TWEB |
| Approvals | CE, RoHS |
