Philio In Wall Single Relay (1 way) Switch Module
This in-wall switch module is a transceiver which is a security enabled device which
based on Z-Wave Plus technology, and it is fully compatible with any Z-WaveTM
enabled network. Mini size design let the module can easily hide itself into the wall
box and that will be good for the house decoration. Since PAN05 supports Security
Command Class, it can learn with Secured controller. Its functionality and supported
command classes is identical when included as a secure and non-secure device.
