Philio PIR Motion Sensor
The Philio PSP05 Philio PIR Motion Sensor Detection in small ball design detects movements at a distance of up to 12 meters. The sensor can be easily installed on the ceiling or a wall thanks to a supplied magnetic holder. Thanks to the unique and discrete design, you can place the sensor anywhere to automate your light. Then your lights switch-on only when the movement is detected, and if there is no person in the room, the lamps do not switch on.
In addition, the Philio PIR Motion Sensor is suitable for outdoor use. This allows you to extend your automation and alarm system to the outside. The sensor is battery-operated and can be easily added to your Ezlo Z-Wave Smart Home System.
