Seco-Larm Enforcer Double Door Electromagnetic Lock, Bond Sensor, 600 Lbs.
Regular price $239.95
Regular price $239.95 Sale price
The Seco-Larm Enforcer Double Door Electromagnetic Lock is the perfect solution for securing your double doors. With a powerful holding force of 600 lbs, this lock ensures that your doors remain securely locked at all times.
The bond sensor further enhances the security by monitoring the bond between the lock and the door, triggering an alarm if the bond is broken. Its easy-to-install design makes it ideal for both commercial and residential use. The Seco-Larm Enforcer Double Door Electromagnetic Lock is the ultimate security solution for your double doors.
Holding Force: 600 pounds (272kg)
Operating Voltage: 12 or 24 VDC ± 10 percent
Current Draw: 500mA at 12VDC, 250mA at 24VDC
Temperature: 14° to 131° F (-10° to 55° C)
Magnet Size: 19-11/16 x 1-5/8 x 1 inches (500 x 42 x 25 mm)
Armature Size: 7-1/4 x 1/2 x 1-1/2 inches (185 x 12 x 38 mm)
Certification: UL, ULC, CE
RoHS Compliance: Yes
Weight: 9 pounds (4kg)
