Seco-Larm Enforcer Electromagnetic Gate Lock, 1,300 Lbs.
Regular price $189.95
Regular price $189.95 Sale price
Secure your gate with the Seco-Larm Enforcer Electromagnetic Gate Lock, capable of holding up to 1,300 lbs of pressure. This lock is the perfect solution for those in need of a reliable and robust option to keep their property safe. The lock is easily installed and compatible with most gate types, making it a versatile option for both residential and commercial properties. With its durable construction, the Seco-Larm Enforcer Electromagnetic Gate Lock is sure to provide years of reliable, secure protection for your property.
Holding Force: 1,300 pounds (545kg)
Operating Voltage: 12 or 24 VDC ±10 percent
Current Draw: 500mA at 12VDC, 250mA at 24VDC
Temperature: 14 to 131° F (-10 to 55° C)
Magnet Size: 8 x 2-1/2 x 1-5/8 inches (203 x 63 x 41 mm)
Armature Size: 7-1/4 x 2-3/8 x 5/8 inches (185 x 61 x 16 mm)
Weight: 10 pounds 8 ounces (5 kg)
Cable Length: 6-1/2 Feet (2 meters)
Certifications: UL, ULC, CE UL for maglock only
