Seco-Larm Enforcer Electromagnetic Gate Lock, 300 Lbs.
Regular price $107.95
Regular price $107.95 Sale price
Secure your property with the Seco-Larm Enforcer Electromagnetic Gate Lock, a powerful locking mechanism that can withstand up to 300 lbs. of force. This durable gate lock is designed to keep intruders out and your property safe. It is made of high-quality materials and features an electromagnetic lock that is activated by a signal from your security system. The lock is easy to install and comes with all necessary hardware, making it a great choice for both residential and commercial properties. With the Seco-Larm Enforcer Electromagnetic Gate Lock, you can have peace of mind knowing that your property is protected.
Holding Force: 300 pounds (136kg)
Operating Voltage: 12VDC, ±10 percent
Current Draw: 315mA at 12VDC
Temperature: 14 to 131 degrees F (-10 to 55 degrees C)
Magnet Size: 6-3/4 x 1 x 1-1/4 inches (170 x 23 x 32 mm)
Armature Size: 6 x 3/8 x 1-1/4 inches (152 x 10 x 32 mm)
Certification: CE
RoHS Compliant: Yes
Weight: 2 pounds, 13.5 ounces (1.29kg)
