Seco-Larm Enforcer Electromagnetic Lock, 80 Lbs.
Regular price $53.95
Regular price $53.95 Sale price
The Seco-Larm Enforcer Electromagnetic Lock is a high-quality security accessory designed to keep your doors firmly locked. This powerful lock is capable of withstanding up to 80 lbs. of force, providing reliable protection for your home or business. With its sleek and modern design, this electromagnetic lock is easy to install and operate. It features a durable metal housing and a powerful magnet that ensures a secure and stable locking mechanism. This lock can be used with a wide range of doors, including wooden, glass, and metal ones. Whether you need to keep intruders out or secure valuable assets, the Seco-Larm Enforcer Electromagnetic Lock is the perfect solution.
Holding Force: 80 pounds (36kg) at 12VDC
Operating Voltage: 12 VDC, ±10 percent
Current Draw: 85mA at 12VDC
Temperature: 14 to 131 degrees F (-10 to 55 degrees C)
Magnet Size: 2-3/4 x 1-1/4 x 3/4 inches (70 x 31 x 19 mm)
Armature Size: 2-3/8 x 1-1/4 x 3/8 inches (60 x 31 x 9 mm)
Certification: CE
RoHS Compliant: Yes
Weight: 14.4 ounces (410g)
