Seco-Larm Enforcer Electromagnetic Lock, Bond Sensor, 1,200 Lbs. with Timer
Regular price $178.95
Regular price $178.95 Sale price
Shop Seco-Larm Enforcer Electromagnetic Lock Bond Sensor, 1,200 Lbs. with Timer
The Seco-Larm Enforcer Electromagnetic Lock is a premier security solution for commercial and industrial facilities requiring robust access control. With an impressive holding force of 1,200 lbs., this Electromagnetic Lock is engineered to withstand the most determined intruders, ensuring maximum security for your premises.
Key Features:
  • 1,200 Lbs. Holding Force: The Seco-Larm Enforcer Electromagnetic Lock provides an exceptional holding force, making it a reliable security measure for high-risk environments. This substantial holding power ensures that doors remain securely closed against unauthorized access.
  • Electromagnetic Bond Sensor: Equipped with an Electromagnetic Bond Sensor, this lock continuously monitors the lock status, ensuring that the door remains engaged even if pushed or pulled. This feature enhances the overall security by providing real-time status updates.
  • Integrated Timer: The built-in timer allows for customizable access control, enabling you to set specific times for the lock to engage and disengage. This feature is particularly useful for managing access during different times of the day or night, ensuring flexibility and control over entry points.
  • Easy Installation: The Seco-Larm Enforcer Electromagnetic Lock is designed for straightforward installation, compatible with a variety of access control systems. Its user-friendly setup ensures that you can enhance your facility's security quickly and efficiently.
Enhanced Security and Flexibility:
The Seco-Larm Enforcer Electromagnetic Lock combines high holding force with advanced features to deliver a superior security solution. The Electromagnetic Bond Sensor provides continuous monitoring, while the integrated timer offers flexible access control options. This combination makes it an ideal choice for facilities that require stringent security measures without compromising on convenience.
Versatile Application:
Suitable for a wide range of applications, the Seco-Larm Enforcer Electromagnetic Lock is perfect for commercial buildings, industrial sites, and other high-security areas. Its robust construction and advanced features ensure that it meets the demands of any security-conscious facility.
Reliability and Performance:
Engineered for reliability, the Seco-Larm Enforcer Electromagnetic Lock offers consistent performance and peace of mind. Its high-quality materials and construction ensure long-lasting durability, making it a cost-effective investment for enhancing security.
Product Specs:
Holding Force: 1,200 pounds (545kg)
Current Draw: 500mA at 12VDC, 250mA at 24VDC
Operating Voltage: 12 or 24 VDC ±10 percent
Temperature: 14° to 131° F (-10° to 55° C)
Magnet Size: 10-1/2 x 1-5/8 x 2-5/8 inches (268 x 42 x 67 mm)
Armature Size: 7-1/4 x 5/8 x 2-3/8 inches (185 x 16 x 61 mm)
Weight: 10 pounds, 8 ounces (5kg)
