Seco-Larm ENFORCER IP 5MP 2.8mm Bullet Camera
$81.95
  • High-Resolution Imaging: Equipped with a 1/2.7" 5MP SmartSens CMOS sensor, the camera captures clear and detailed footage at a resolution of 2880×1620 pixels at 30 fra..
  • Wide-Angle Lens: The 2.8mm fixed lens offers a broad 110° horizontal field of view, providing extensive coverage ideal for monitoring large outdoor areas
  • Advanced Video Compression: Supports H.265, H.264, and MJPEG triple stream encoding, reducing bandwidth and storage requirements without compromising video quality
  • True Wide Dynamic Range (WDR): Enhances image quality in challenging lighting conditions by balancing light and dark areas, ensuring clear footage in high-contrast env..
  • Digital Noise Reduction (3DNR): Minimizes image noise in low-light conditions, resulting in clearer and more accurate video
Shop Seco-Larm ENFORCER IP 5MP 2.8mm Bullet Surveillance Outdoor Camera
The Seco-Larm ENFORCER IP 5MP 2.8mm Bullet Camera is a high-performance outdoor camera designed to deliver superior surveillance capabilities for both residential and commercial applications. With its advanced features and robust construction, this ENFORCER bullet camera ensures reliable security monitoring in various environments.
  • High-Resolution Imaging: Equipped with a 1/2.7" 5MP SmartSens CMOS sensor, the camera captures clear and detailed footage at a resolution of 2880×1620 pixels at 30 frames per second, ensuring critical details are recorded
  • Wide-Angle Lens: The 2.8mm fixed lens offers a broad 110° horizontal field of view, providing extensive coverage ideal for monitoring large outdoor areas.
  • Advanced Video Compression: Supports H.265, H.264, and MJPEG triple stream encoding, reducing bandwidth and storage requirements without compromising video quality.
  • True Wide Dynamic Range (WDR): Enhances image quality in challenging lighting conditions by balancing light and dark areas, ensuring clear footage in high-contrast environments.
  • Digital Noise Reduction (3DNR): Minimizes image noise in low-light conditions, resulting in clearer and more accurate video.
  • Day/Night Functionality with IR Cut Filter (ICR): Automatically switches between color and black-and-white modes, utilizing two built-in 850nm IR LEDs to provide clear night vision up to 98 feet (30 meters).
  • Weatherproof and Durable Design: With an IP66 weatherproof rating, this surveillance outdoor camera is built to withstand harsh weather conditions, making it suitable for various outdoor installations.
  • Power over Ethernet (PoE) Support: Simplifies installation by allowing the camera to receive power and data through a single Ethernet cable, reducing the need for additional wiring.
  • AI-Powered Functions: Includes advanced features such as face detection, human and vehicle detection, license plate recognition, perimeter intrusion detection, and more, enhancing the effectiveness of your security system.
  • Enhanced Security: Provides high-definition surveillance, ensuring critical areas are monitored with clarity and precision.
  • Versatile Application: Ideal for various settings, including homes, offices, retail stores, and industrial sites, offering flexibility in deployment.
  • Cost-Effective Storage: Advanced video compression reduces storage requirements, lowering costs associated with data storage solutions.
  • Reliable Performance: Designed to operate in extreme temperatures ranging from -40°F to 131°F (-40°C to 55°C), ensuring consistent performance in diverse environmental conditions.
The Seco-Larm ENFORCER IP 5MP 2.8mm Bullet Camera is suitable for a wide range of outdoor surveillance applications. Its robust features make it an excellent choice for monitoring entrances, perimeters, parking lots, and other critical areas where high-quality video capture is essential.
Incorporating this ENFORCER bullet camera into your security system enhances your ability to monitor and protect your property effectively. Its combination of advanced imaging technology, durable construction, and intelligent features makes it a reliable solution for comprehensive outdoor surveillance.
