The Sensaphone Carbon Dioxide (CO2) Sensor is an essential device for maintaining optimal air quality in various indoor environments. This advanced carbon dioxide sensor is designed to detect and measure CO2 levels with high precision, ensuring that your space remains safe and healthy. Ideal for homes, offices, industrial facilities, and warehouses, the Sensaphone Carbon Dioxide Sensor provides real-time monitoring, alerting you to any potentially harmful increases in CO2 concentration.
With easy installation and compatibility with a wide range of Sensaphone monitoring systems, this CO2 sensor is a versatile tool for maintaining air quality. Its robust design ensures long-lasting performance, making it an indispensable component for environments where air quality is critical. The Sensaphone Carbon Dioxide Sensor helps you stay informed about your indoor environment, enabling proactive measures to ensure the well-being of occupants and adherence to safety standards.
Usage, Benefits, and Importance:
Usage: The Sensaphone Carbon Dioxide Sensor is used to monitor CO2 levels in various indoor settings, providing real-time data that helps in maintaining safe and healthy air quality. It is compatible with Sensaphone systems for seamless integration into existing monitoring setups.
Benefits: Accurate CO2 monitoring helps prevent respiratory issues, ensures compliance with health and safety regulations, and improves overall indoor air quality. The sensor's reliable performance and easy installation make it a practical choice for both residential and commercial applications.
Importance: Maintaining proper CO2 levels is crucial for the health and safety of individuals in indoor environments. The carbon dioxide sensor provides critical data that enables timely intervention, preventing potential health risks associated with poor air quality.
Product Specs:
CO2 Range
0-2,000 PPM
Accuracy
± 50 PPM
Operating Temp Range
32° to 122° F (0° to 50° C)
Response Time
2 Minutes for 90% step change
Housing
White plastic
Compatibility
Sensaphone 1400, 1800, 2000, 2800, Express II, SCADA 3000, WEB600
