Skylink Garage Door Opener 3-Button Keychain Transmitter
$26.95
Three-Button Functionality: The 3-Button Keychain Transmitter allows you to open, close, or stop your garage door with the press of a button. This functionality provid..
Extended Range: With a range of up to 100 feet, you can operate your garage door from a distance, providing added convenience and flexibility
Wide Compatibility: The Garage Door Opener Transmitter works with most garage door openers, making it a versatile addition to your garage setup
Durable Construction: Built to last, this transmitter is designed to withstand everyday wear and tear, ensuring reliable performance for years to come
The Skylink Garage Door Opener 3-Button Keychain Transmitter is a convenient and reliable solution for controlling your garage door. Its compact size makes it easy to attach to your keychain, ensuring quick access whenever you need it.
Key Features:
- Three-Button Functionality: The 3-Button Keychain Transmitter allows you to open, close, or stop your garage door with the press of a button. This functionality provides you with full control over your garage door operations.
- Extended Range: With a range of up to 100 feet, you can operate your garage door from a distance, providing added convenience and flexibility.
- Wide Compatibility: The Garage Door Opener Transmitter works with most garage door openers, making it a versatile addition to your garage setup.
- Durable Construction: Built to last, this transmitter is designed to withstand everyday wear and tear, ensuring reliable performance for years to come.
Benefits:
- Compact and Portable: The small size of the 3-Button Keychain Transmitter makes it easy to carry with you, whether it's on your keychain or in your pocket, ensuring you always have control of your garage door at your fingertips.
- User-Friendly Design: The simple and intuitive design allows for easy operation, so you can quickly and effortlessly control your garage door.
- Enhanced Security: By keeping the Garage Door Opener Transmitter with you, you can ensure that only authorized individuals have access to your garage, enhancing the security of your home.
- Range: Up to 100 feet
- Buttons: Three (open, close, stop)
- Compatibility: Works with most garage door openers
- Construction: Durable and compact design
Upgrade your garage door control with the Skylink Garage Door Opener 3-Button Keychain Transmitter. Its reliable performance, ease of use, and versatile compatibility make it the perfect accessory for any garage.
Product Specs:
| Battery | One (1) Lithium Battery CR-2032 (installed) |
| Approvals | FCC, IC |
| Warranty | 1 Year |
