SkylinkHome Plug-In On/Off Control (Indoor/Outdoor)
$26.95
The SkylinkHome Plug-In On/Off Control is the perfect solution for controlling your indoor and outdoor electrical devices with ease. With this device, you can remotely turn on and off any plugged-in appliance or light, without having to get up from your seat.
This innovative device is designed to work with any standard wall outlet and is incredibly easy to install. Simply plug it in, connect your device, and you're ready to go. The SkylinkHome Plug-In On/Off Control is compatible with most electrical devices, including lamps, fans, heaters, and more.
Featuring a sleek and compact design, this device is perfect for both indoor and outdoor use. It's also incredibly convenient, allowing you to turn your devices on and off with just the push of a button. Whether you're at home or away, this device provides you with complete control over your electrical devices, making your life easier and more efficient.
With its reliable and durable construction, the SkylinkHome Plug-In On/Off Control is built to last. It's also incredibly energy-efficient, helping you save money on your energy bills. So if you're looking for a convenient and reliable way to control your electrical devices, the SkylinkHome Plug-In On/Off Control is the perfect solution.
| Input: |
| Minimum Load: | 10W |
| Maximum Rating: | 15 Amps |
| Maximum Load: | 1500W at 120VAC |
| Operating Frequency: | 318MHz |
| Operational Temperature: | -4° to 140°F (-20° to 60°C) |
| Wireless Range: | Up to 500 feet in open area |
| Approvals: | FCC, UL |
| Warranty: | 1 Year |
