Smart 24G Human Presence+Pir+Luminance 3In1 Sensor Zigbee3.0 for Tuya Home Assistant Zigbee2Mqtt Battery Power 3Years
Lincukoo Tuya zigbee3.0 Smart 3in1 Human Motion and Presence Sensor 9m Built in PIR sensor 24G Microwave Radar sensor home assistant zigbee2MQTT
Important Note:
This Sensor can be used on Tuya or Home Assistant platform need connect toordongle
Tip: In order to save your usage costs, this product is shipped with a battery included
--This 3in1 sensor can detect human motion and presence, luminance value in real time, it can recognize the trigger is caused by human or other objects, so that optimized the false trigger issue
--It has 2working modes (presence mode, motion + presence mode), to meet kinds of needs for person detection,
the presence mode monitors if there is someone in the range for long time.
the motion+ presence mode will detect if there is human action first, the radar only starts to monitor after human action is detected, so that to reduce the false trigger issue
-It can scan and calibration the enviroment automatic so that user do not need set the sensitivity and the hold on time, its detect range of presence mode is 9meters, and the motion + presence mode is 6meters, the hold on time(the delay after a person leaves the detect range(5-60senconds) are adjustable, and the luminance range is 0-1000lux.
-The pre-install 2*AA batteries can be used for 2yeas at least (the duration may vary depending on the usage environment), even if low battery alarm, still can last for 1-2months, when user use the USB power in, the battery is backup, no power consume
-Suitable for rooms that require the light/air conditioner/curtain etc to be turned on when someone is present for long time and turned off when there is no one there, such as meeting room, reading room, living room, kitchen, washing room…
-Support linkage with other devices through gateway, for example, if there is someone is detected in range, turn on the light and keep, until there is no one in the range, then turn off the light.
Platform support:Tuya , Home Assistant
Transmission Protocol :Zigbee
Zigbee to MQTT support :Yes
Transmission distance(max):40meters
Detection mode:Presence mode, Motion +Presence mode
Adjustable detect range :3-9meters(Presence mode), 3-6meters(Motion + Presence)
Adjustable sensitivity: Auto
Adjustable hold on time:Auto
Luminance Range:0-1000lux
Power in:2*AA battery , 5v type-c
IP grade :IP64
Install mothed:Double-sided tape, Screw,Magnetic installation
Certification :CE,Rohs,FCC
