Smart Zigbee 3.0 Door Window Sensor Lux Light Detect 2 in 1 Real Time Wireless Magnetic Alarm App Remote Control Home Security
Smart ZigBee 3.0 Door Window Sensor Lux Light Detect 2 in 1 Real Time Wireless Magnetic Alarm App Remote Control Home Security
Compatible with Built-in Zigbee Hub: A built-in Zigbee hub is required to use the Zigbee Door Window Sensor. Please note that the hub is sold separately.(Not all Amazon Echos have a Zigbee hub built-in, but for those that do, it gives you the freedom to create a more local-focused smart home.)
Smart Home Automation: The Zigbee Door Window Sensor can automatically control other Zigbee-enabled accessories through routines, such as Home Assistant, Hubitat, or Alexa Echo Devices--which include the Echo 4th generation, Echo Plus 1st and 2nd generation, Echo Show 10 2nd and 3rd generation, Echo Studio, Eero 6, and Eero Pro6.
Get Notified & Double-check on the Spot: Get immediate app notifications on your smartphone for doors and windows open/closed with Zigbee Door Window Sensors. uses voice commands to see the doors and windows' current open/closed state at a glance, and controls the routines/scenes for peace of mind.
Hassle-free Setup: The Mini-sized Smart Contact Sensor is easy to install anywhere without tools and can be detected by Alexa Echo devices with the command "Alexa, discover devices".
Specification
Item: Zigbee Door Window Sensor/with Lux Detect
Wireless Protocol: Zigbee 3.0(need zigbee gateway)
Sensing Distance: ≥15mm
Working Voltage: 3V
Battery Type: CR2032(included)
Standby Current: ≤12uA
Operating Temperature: -10~55℃
Operating Humidity: 0%~99%RH
Luminance Meter: 0~1000lux
