Smart Zigbee Solar Soil Sensor Planting Temperature and Humidity Meter IP66 Waterproof Wireless Soil Moisture Meter Garden Automation Irrigation Detector for Turf Gardening Feature: 1. Smart Solar-Powered Sensor: The Planting Temperature and Humidity Meter features high-efficiency solar panels and rechargeable batteries for long-lasting power. Its 1.2V*3 NiMH battery ensures extended use, perfect for sustainable gardening. 2. Accurate Temperature and Humidity Testing: The Wireless Soil Tester utilizes Zigbee 3.0 technology for precise soil temperature and humidity sensing, ensuring optimal plant growth conditions and safeguarding your garden environment. 3. Convenient Remote Management: With the Thermohygrometer, use the app to monitor temperature and humidity data in real-time. Stay informed about your plants' status, view historical records, and switchs between Celsius and Fahrenheit for comprehensive insights. 4. Zigbee Wireless Long-Distance Transmission: The Wireless Soil Moisture Meter requires pairing with a gateway for operation, enabling seamless long-distance data transmission and integration into your smart home ecosystem. 5. Intelligent Linkage Control: The Garden Automation Irrigation Detector features smart scene linkage, automatically pairing with smart sprinklers to adjust watering based on soil moisture, creating an automated maintenance system for your garden.
Specification: Origin: Mainland China Communication method: zigbee Color: Gray Purple Battery: AA 1.2V * 3 NiMH batteries (rechargeable) included Solar charging current: 35mA Communication protocol: Zigbee 3.0 Wireless protocol: Zigbee IEEE 802.15.4 Wireless distance: 50M Waterproof grade: IP66 Temperature detection range: -10-60℃(14℉-140℉) Humidity detection range: 0-100%RH (no condensation) Conductivity maximum detection range: 20ms/cm Temperature detection accuracy: 0.5℃ (adjustable) Humidity detection accuracy: 5%RH (adjustable) Conductivity detection accuracy: 3%FS 0.01ms/cm Detection time span: 10min (adjustable) Working temperature: -10-60℃ (14-140℉) Working humidity: 0~100%RH (no condensation) Dimensions: 146*78*78mm/5.75x3.07x3.07inch Packaging size: 150*100*100mm Gross weight: 254g
Note: Due to different monitor settings and lighting conditions, the actual color of the item may vary slightly from the pictures. Thanks for your understanding! Please allow a 1-2 cm difference in measurements due to manual measuring.
1 x Solar Soil Sensor 1 x Screw Pack 1 x Instruction Manual
