SNZB-02WD for Zigbee 3.0 for Smart Temperature Humidity Sensor IP65 Waterproof LCD Display for Greenhouse Bathroom Industrial Mo
$45.56
Features:
*IP65 Waterproof Rating: The SNZB-02WD sensor is designed with an IP65 waterproof rating, making it highly suitable for environments that are prone to moisture, such as greenhouses and bathrooms, reliable performance in wet conditions.
*Real-Time Monitoring: Featuring for ZIGBEE technology, this device provides real-time temperature and humidity readings displayed on an easy-to-read LCD screen, allowing users to for ACCESS data quickly via the dedicated app.
*Data Visualization & Export: The accompanying app allows users to view and export detailed charts of temperature and humidity over time, facilitating effective monitoring and management of conditions in spaces like warehouses and greenhouses.
*Breathable Membrane Technology: The sensor includes a waterproof and breathable membrane, accurate measurements by moisture from affecting its performance, thereby delivering stable even in humid environments.
*Versatile Installation Options: With flexible installation methods, the sensor can be magnetically attached or hung, making it adaptable to various settings—ideal for different layouts in greenhouses, bathrooms, or industrial spaces.
*Part Name: Smart Temperature & Humidity Sensor
*Material:PC
*Size:62.8*21.8*58.5mm
*Color:WHITE
*IP Protection Rating: IP65
* Model: CR2477
*Casing Material: PC+ABS
*Color: White
*Wireless Connection: for ZigBee 3.0
*Operating Temperature: -20℃~60℃
*Input: 3V
*Operating Humidity: 0~100%RH
Package Content:
1*Smart Temperature & Humidity Sensor
Note:
1. The real color of the item may be slightly different from the pictures shown on website caused by many factors such as brightness of your monitor and light brightness.
2. Please allow slight manual measurement deviation for the data.
