Somfy Battery Charger for Irismo 45 WireFree RTS
$109.95
Efficient Charging: Quickly and reliably charges the battery of your Irismo 45 WireFree RTS motor
Easy to Use: Simple plug-and-play functionality for hassle-free operation
Versatile Compatibility: Works with all Somfy Irismo 45 WireFree RTS motors
Compact Design: Sleek and unobtrusive, perfect for any setting
The Somfy Battery Charger for Irismo 45 WireFree RTS is an indispensable accessory designed to keep your Somfy Irismo 45 motor running smoothly. Specifically crafted for the Irismo 45 WireFree RTS series, this charger ensures your motor's battery is always fully charged and ready to perform, whether you’re automating curtains, blinds, or other window coverings.
Reliable and Efficient Charging
Designed for convenience, the Battery Charger for Irismo offers reliable and efficient charging for your motor. Simply connect it to the Somfy Irismo 45 WireFree RTS motor, and it will quickly recharge the battery, minimizing downtime and ensuring continuous operation. The charger's sleek and compact design allows it to blend seamlessly into any home or office environment, making it a practical addition to your automation toolkit.
Easy to Use
With a user-friendly interface, the Charger for Irismo 45 is straightforward to use. Simply plug it into a standard outlet and connect it to your Irismo 45 motor for hassle-free charging. Its intuitive design ensures that even first-time users can easily handle the charging process, providing a stress-free experience.
This Battery Charger for Irismo is compatible with all models of the Somfy Irismo 45 WireFree RTS series, making it a versatile choice for all your motorized window treatment needs. Whether you're using it at home or in a commercial setting, this charger guarantees your motor remains powered and ready to go at all times.
Key Benefits
- Efficient Charging: Quickly and reliably charges the battery of your Irismo 45 WireFree RTS motor.
- Easy to Use: Simple plug-and-play functionality for hassle-free operation.
- Versatile Compatibility: Works with all Somfy Irismo 45 WireFree RTS motors.
- Compact Design: Sleek and unobtrusive, perfect for any setting.
Why Choose the Somfy Battery Charger?
Keeping your motorized window treatments operational is crucial for convenience and comfort. The Somfy Battery Charger for Irismo 45 WireFree RTS ensures that your motor's battery remains charged, so you can enjoy the benefits of automated window coverings without interruption. Invest in this reliable charger and experience peace of mind, knowing that your motorized system is always ready to perform.
Product Specs:
| Manufacturer Part #: | 1003080 |
| Power Supply: | 26.5V |
| Additional Bullets: | Details |
