Somfy DecoFlex WireFree RTS Wall Switch, 2-Channel, Black
The Somfy DecoFlex WireFree RTS Wall Switch is the perfect solution for controlling your window coverings with ease and convenience. This 2-channel switch allows you to control two different window coverings from one location, making it ideal for larger rooms or multiple windows. With its sleek and modern black design, this wall switch will seamlessly blend in with any decor. And because it's wire-free, installation is a breeze - no drilling or wiring required! Simply mount the switch on the wall and you're ready to go. Compatible with Somfy's RTS motors, this wall switch provides reliable and precise control of your window coverings, giving you the ultimate in comfort and convenience. Upgrade your home with the Somfy DecoFlex WireFree RTS Wall Switch today!
