Somfy RTS Transmitter with Dry Contact Inputs, 1-Channel
$132.95
The Somfy RTS Transmitter with Dry Contact Inputs is a state-of-the-art device that provides you with reliable and efficient control over your home automation systems. With a 1-channel output, this transmitter is perfect for controlling one device, such as a motorized window shade or awning. It comes equipped with dry contact inputs that allow you to easily integrate it with your existing home automation system. The transmitter is designed to work seamlessly with Somfy RTS receivers, providing you with a robust and reliable wireless control system. The compact and sleek design of the transmitter makes it easy to install and use, while its advanced features ensure that you have complete control over your home automation systems. With the Somfy RTS Transmitter with Dry Contact Inputs, you can easily automate your home and enjoy the convenience of wireless control.
