Somfy SDN Power Over Ethernet Gateway
$281.95
Seamless Integration: The SDN Ethernet Gateway effortlessly integrates with various Somfy home automation products, providing centralized control
Power Over Ethernet (PoE): The PoE capability ensures efficient and reliable operation by powering the device directly through the Ethernet cable, eliminating the need..
Remote Control: Manage your Somfy devices from anywhere using your smartphone, tablet, or computer
User-Friendly Interface: The intuitive dashboard allows for easy management, scheduling, and scene creation
Energy Efficiency: Enhance the comfort and convenience of your home while improving energy efficiency
The Somfy SDN Power Over Ethernet Gateway is a state-of-the-art device that seamlessly integrates various Somfy home automation products. With advanced features and capabilities, this SDN Ethernet Gateway allows you to control your Somfy-powered blinds, shades, and other devices from anywhere using your smartphone, tablet, or computer.
This gateway supports Power Over Ethernet (PoE) technology, enabling it to be powered directly through the Ethernet cable, which eliminates the need for a separate power supply. This ensures that the Somfy Ethernet Gateway operates efficiently and reliably, even in areas with limited power sources.
Designed to work seamlessly with Somfy’s Smart Home Automation system, the SDN Power Over Ethernet Gateway provides a simple and intuitive interface for controlling all your Somfy devices. Its easy-to-use dashboard allows you to manage your devices, create schedules, and set up custom scenes with just a few taps on your mobile device.
Benefits and Features of Somfy Ethernet Gateway:
- Seamless Integration: The SDN Ethernet Gateway effortlessly integrates with various Somfy home automation products, providing centralized control.
- Power Over Ethernet (PoE): The PoE capability ensures efficient and reliable operation by powering the device directly through the Ethernet cable, eliminating the need for a separate power supply.
- Remote Control: Manage your Somfy devices from anywhere using your smartphone, tablet, or computer.
- User-Friendly Interface: The intuitive dashboard allows for easy management, scheduling, and scene creation.
- Energy Efficiency: Enhance the comfort and convenience of your home while improving energy efficiency.
Whether you're looking to enhance the comfort and convenience of your home or improve your energy efficiency, the Somfy SDN Power Over Ethernet Gateway is the perfect solution. With its advanced features and reliable performance, this device is sure to make your life easier and more enjoyable.
| Manufacturer Part #: | 1860326 |
| Input Power: | UPoE/IEEE 802.3bt up to 60W |
| Output Power: | 24V DC @ 2A |
| Input Data: | Ethernet CoAP |
| Output Data: | SDN RS485 |
| Standby Power Consumption: | 0.5 W |
| Material: | Extruded Aluminum |
| Operating Temperature Range: | 32°F (0°C) to 104°F (40°C) |
| Dimensions: | 4.7 in. L x 2.1 in. W x 1.0 in. H |
| Maximum Wiring Distance: | Cumulative from Gateway to all motors: 240 ft. when using Liberty AV 9020126 or 9020127 cable Cumulative from Gateway to Keypad: 200 ft. using cat5e cable |
| Shipping Weight: | 1 lb. |
| Usage: | Indoor use only |
