Somfy Telis 16 RTS Pure Remote with Display, 16-Channel
The Somfy Telis 16 RTS Pure Remote with Display is the ultimate solution for controlling your home's motorized devices. With 16 channels, this remote allows you to operate up to 16 different motorized devices, including shades, blinds, and awnings, with ease. The clear display on the remote shows the current status of each device, making it easy to identify which device is currently in use. The remote's sleek and elegant design fits comfortably in your hand while its intuitive interface ensures effortless control. The Somfy Telis 16 RTS Pure Remote with Display is the perfect choice for those who demand the best in functionality and design.
Product Specs:
| Battery Type | LR03 AAA Battery |
| Battery Voltage | 1.5V |
| Radio Frequency | 433.42 MHz |
| Indoor Range | 20 m with two reinforced concrete walls |
| Operating Temperature | 0 to 60 degrees F (-18 to 15 degrees C) |
| Finish | Pure |
| Dimensions | 47(L) x 151(H) x 18(D) inches |
| Protection Index | IP30 |
