Speaker Wire, 12AWG, 2C, Direct Burial, Oxygen Free, 500 Ft.
Regular price $534.95
Regular price $534.95 Sale price
Introducing our top-of-the-line Speaker Wire, 12AWG, 2C, Direct Burial, Oxygen Free, 500 Ft. This premium speaker wire is designed to deliver exceptional sound quality and durability for all your audio needs. With a 12-gauge thickness and 2 conductors, it provides a secure and stable connection between your audio equipment and speakers.
Our Speaker Wire is also Direct Burial rated, meaning it can be installed directly underground without the need for conduit or protective covering. This makes it ideal for outdoor speaker installations, providing a reliable and long-lasting connection in any weather conditions.
Made with oxygen-free copper, this speaker wire ensures minimal signal loss and interference, resulting in clear and crisp audio playback. And with a generous 500 ft. length, it provides plenty of wire for even the most complex speaker systems.
Whether you're setting up a home theater, sound system, or outdoor speakers, our Speaker Wire is the perfect choice for superior sound quality and hassle-free installation. Buy now and experience the difference for yourself!
Manufacturer Part # 12/2OFC-HD-WT
Marking STRUCTURED CABLE PRODUCTS – – – 12/2OFC-HD E198137 SCP3 (UL) CL3 C(UL) CMR 2C 12AWG 65 STRAND OXYGEN FREE COPPER INDOOR/OUTDOOR-SUN RES FT4 75C CE RoHS ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 ***M
Construction Characteristics Conductor Material: Stranded Bare Copper
Size: 12AWG x 2C (3.32mm^2)
Construction: 65/0.254mm ±0.004mm
Insulation Material: PVC
Min. Thickness: 0.33mm
Avg. Thickness: 0.36mm
Diameter: 3.20mm ±0.05mm
Colors: Black and Red
Jacket Material: PVC
Min. Thickness: 0.80mm
Avg. Thickness: 0.95mm
Diameter: 8.3mm ±0.20mm
Rip Cord: Nylon
Color: White
Electrical & Physical Characteristics Operating Temperature Range: –20°C to +70°C
Conductor Resistance: Max 5.8 ohm/km at 20°C
Insulation Resistance: Min 50M ohm*km at 20°C
Dielectric Strength: Min AC1.5KV
Insulation Unaged:
Tensile Strength: 13.8Mpa
Elongation: 100 percent
Insulation Aged:
Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 50 percent (100°C 168h)
Jacket Unaged:
Jacket Aged:
