Truth Sentry II HS Motor System Cover, White
$33.95
The Truth Sentry II HS Motor System Cover in White is a must-have accessory for your home or office windows. Designed to fit perfectly over the motor system, this cover provides protection from the elements, ensuring your motor system stays in top condition for years to come.
Made from high-quality materials, it is built to withstand harsh weather conditions and is easy to install. The white color helps to blend seamlessly with most window frames, adding a sleek and modern look to your windows. With the Truth Sentry II HS Motor System Cover, you can rest assured that your windows are well-protected and will continue to perform at their best.
| Manufacturer Part #: | 12481.32 |
| Color: | White |
| Warranty: | 1 Year |
