Tuya Smart Wifi Water Leak Sensor Water Overflow Level Detector 80Db Sound Alarm System Flood Leakage Sensor Remote Monitor
These are two size to choose ,pls check :
Type1-wifi Water leak detection:
Product parameters:
◆ APP name: for Tuya Smart or Smart Life
◆ Battery type: AAA1.5V*2 (Not included in shipment)
◆ Low-battery remind function
◆ WIFI: 2.4G
◆ Water leak detection
◆ Support all Tuya smart product Linkage control
◆ Working Temperature: -10℃~40℃
◆ Sound level: 80dB(within 1m)
◆ Working Humidity: 20%~85% RH
◆ Storage Humidity: 10% ~ 90% RH
● Dimensions: 91X21X25 cm
◆ Wire Length: 1M (probe cable)
◆ Alarm current: ≤100mA
◆ Standby current: ≤18uA
Type2-Zigbee Water leak detection:
Zigbee version need a tuya zigbee hub to operate.
[Ultra-long battery life, low battery reminder] Low power consumption technology. The use of high-performance, low-power microprocessor, battery life of up to 1 year, to avoid frequent battery replacement (if the daily reminder of 20 times), the battery power is too low to send timely alarm notificatio
Specification:
Communication mode: zigbee 3.0
Supply voltage: DC3V (CR2032 battery, included)
Material: Fireproof PC + fireproof ABS
System support: lOS8.0/Android4.0 and above
Application Name: Smart Life/TUYA
Operating frequency: 2.4GHz
Wireless technology: Zigbee 3.0
Wireless Distance: Indoor 30~50 metres
Operating temperature: -10℃~50
Packing list: 1 sensor, 1 manual (battery included)
APP Remote Control
Mobile APP control, connected to the network via wifi, remote control at any timeAlarm System
When water comes into contact with the sensor, it will connect to your WiFi and send you an alert through the applicationLow Battery Reminder
There is a reminder on APP,if the batterylevel of the sensor is lowTwo main monitoring modes
Water Leakage Monitoring,Low Water Level Monitoring
