Tuya Smart WIFI Zigbee Water Leakage Sensor Alarm Water Detector Flood Leakage Sensor APP Remote Control Security Alarm System
Note: Zigbee version need to work with gateway!!!
Description:
APP:Smart Life / Tuya Smart
WiFi Frequency:2.4G WiFi (Not Support 5G)
Operating Temperature:-30℃~ 70℃
Material:Superior ABS
Feature 1:Water Leak Alarm
Feature 2:Flood Overflow Alarm
1.REAL-TIME MONITORING AND ALARM: The device connects via WiFi to monitor water levels and leaks in real time and sends an alert message to your cell phone as soon as an abnormality occurs, ensuring that you are able to take timely action to minimize potential damage.
2.EASY TO INSTALL: Graffiti WiFi Smart Flood Alarm is easy to install, no wiring required, just fix the device near the water source and use it, very convenient.
3.SENSITIVE AND FAST DETECTION: The device adopts high sensitivity sensors, which can quickly detect changes in water level and water leakage and send out timely alerts to ensure you can react quickly.
4.WATER LEVEL DETECTION AND WATER LEAK DETECTION: Graffiti WiFi Smart Flood Alarm not only detects the water level, but also detects the water leakage, which provides you with more comprehensive home security.
5.Long Standby Time: The device is designed with low power consumption, which can standby for a long time without frequent battery replacement, ensuring the continuous working of the device, so you can use it with more peace of mind.
6.Intelligent management: Through the mobile APP, you can remotely monitor the water level and water leakage anytime and anywhere, and you can set the alarm threshold, timer switch and other intelligent functions to make your life more intelligent and convenient.
Package Included:
1*sensor
Describe:
Low-consumption / Easy to Install / Push notifications / WIFI Connection / Remote Monitoring / Water Leak
WATER LEAKAGE DETECT
When the sensor touches to the water ,it will trigger and get notifications via app
Just 2.4G-WLAN 802.11 b/g/n
Working Principle
When the two feet of the detector was immersed by the water, the alert notifications will be pushed to your phone, be aware of water overflowing in time, reducing flooding risk.
APP Remote Control
Mobile APP control, connected to the network via wifi, remote control at any time.
Install the detector close to Ground , When detected the water in the ground It will be triggered to Alarm.
Water-Level Alarm
Put water-leakage detector at testing location, probe detects water-level over-high, it sends out alarm notification through App.
How it works?
When water touches the sensor, it connects to your WiFi and sends you an alert through the Tuya app.
Water-level alarm / Water leakage alarm
Alarm Records Real-time Query
The old man forgot to turn off the water / Children play with water / Pets drink water
Water pipe burst / Washing machine leakage / Water leakage in Fish tank
