Tuya Wifi/Zigbee Smart Human Presence Detector Millimeter Wave Radar Detection Sensor for Home Security and Energy Conservation
Set the sensitivity from 1-9 to your own need,together with minimum detect range as 0.00m and maximum as 9.5m for flexible detection demand.Meanwhile,it is designed with hold time set as 0-1500s and detection latency set as 0-10s to avoid irrelevant annoying movement and reduce false alarm rate.
Network: ZigBee3.0 / Wifi.
Bluetooth version: Bluetooth 5.0
Radar transmitting frequency: 5.8GHz
Celling mount sensor input: 80-240VAC.
Wall mount sensor input: Micro USB 5V 1A
Maximum detection distance: 11m
Sensitivity: 1-9(default 7)
Wall mount sensor sensing distance: 0.3-9m(Default 6m).
Celling mount sensor sensing radius: 0-7m(Default 5m).
Directly opposite the vertical plane 30°
Detection angle: Directly opposite the horizontal plane 100°
Illuminance Sensor: 0-2000 LUX.
Target detection confirmation time:0-10s
Target disappearance delay time:2-1500s.
Celling Mount Size: :Φ61*H39 mm
Celling Mount Opening Size: 53-58mm
Wall Mount Size: Size:65mm x 65mm x 12mm
Package list:
Human presence sensor*1
User manual*1
Plug(Celling Mount)
USB Cable*1(Wall Mount)
