Tuya Zigbee Smart Knob Switch Wireless Scene Button Rotatable Dimmer Switch Home Appliances Automation Linkage Remoter
NOTE:
1.This product can only be used if it is connected to the Tuya Zigbee gateway
2. It does not support 2mqtt
Specifications
Item: Zigbee smart knob scene switch
Wireless Protocol: Zigbee (need Tuya Zigbee Gateway)
Working Voltage: 3V
Standby Current: ≤8uA
Battery Type: CR2450(include battery)
App: Smart Life / Tuya Smart
Working Temperature: -10°C~55°C
Working Humidity: ≥90%
Weight:58g
【Two-in-one device for wireless scene】In the scene mode, the button respectively support single click, double click scene requirements. You don't need to click the scene mode on your phone, just click the ZigBee smart remote control to open the smart scene.
【Wireless control of ZigBee dimming lamp in remote mode】Add an intelligent knob switch in tuya intelligent ZigBee gateway, and then add an intelligent ZigBee light bulb under the remote dimming interface in the App, so you can remotely control your lamp wirelessly. (Note: Only ZigBee lamp can be added for control)
【Four operations under remote mode to meet different demands】Single press to ON/OFF the bulb,rotate to normal dimmer,double press and rotate to set the color temperature,and long press more than 3 seconds to set color,which clarifies the real-sense of value for money with this mini excellent device.
【Create multiple intelligent scenes for smart devices in App under scenario mode】To create any smart automation as you want on your smart phone app to start your another intelligent lifestyle, when you are tired from one-day work,such as home mode, waterproof level up to IP55 for wider applications.
Packing List:
Knob*1
Manual*1
Sticker*1
