Have an account?
Loading...
We use magnetic retention relays, which can be used as single-zero-fire without the need for a neutral wire.
SPECIFICATION
--Specifications:Fully compatible for US AU--Power supply mode:Neutral+live wire--Encryption type:WEP/AES/TKIP--Rated voltage:AC100V-250V(50/60Hz)--Static power loss ≤0.5W--Load power:INC600W(Max) LEDISOW(Max)--Working environment -20℃~75℃--Working humidity:<95%--Wireless standard:IEEE802.11b/g/n--Controlling distance:no distance limitation--Working frequency:2.412-2.484MHZ--Product size:116*75*35MM--Wireless security support:WEP/WPA-PSK/PA2-PSK
Package List
--Smart Switch*1
--User Manual*1
--Screw*2
Smart Wall Light SwitchIntelligent Remote Control Switch With 1/2/3 Gang
Start Building Your Ezlo Home
Tuya Zigbee Smart Light Wall Light Switch US/AU NO Neutral Wire Push Button Physical Remote Control Switches Alexa Google Home
