Tuya Zigbee Smart Vibration Sensor Detection Tilt Sensor Smart Life App Notification Shock Alarm Record Work with Alexa Z2M
2025/7/22 update version: It support tuya and smart life App/tuya zigbee hub.
Specification
Working voltage: DC 3V
Wireless connections: ZigBee 3.0(need to use zigbee hub)
Standby current: ≤15uA
Standby time: ≥15 months
Battery: CR2450 (battery include)
Weight range: ±2g
Tilt range: ±10°
Working temperature: -10°C~50℃
Working humidity: ≤95%
App: Tuya/Smart Life
Package Content
1* Zigbee Smart Vibration Sensor
1* User Manual
1* Reset Pin
1* Double-sided Sticker
1* CR2450 Battery
【Vibration Detection Sensor】Enable the vibration detection function in the Smart App. When the device detects vibration, the APP alarm notification function will be triggered. Really monitor your home safety.
【Tilt Detection Sensor】Enable the tilt detection function in the Smart App. When the sensor tilts, the App alarm notification function will be triggered.
【Sensitivity Setting】You can set the sensitivity in the App according to your needs, with a wide range from low to high; support historical records to monitor your home more accurately.
【Real-time Remote Monitoring】No matter when and where, once the vibration sensor detects vibration or movement, you will receive a push notification from your smartphone in the Smart App as real-time monitoring.
【Smart Linkage】The vibration sensor can be used in conjunction with other smart products to achieve smart linkage for the whole house (smart scenes need to be created)
