Tuya Zigbee SPI LED Controller Dimmer 5V 12V 24V WS2811 WS2812B SK6812 RGB/RGBW Addressable LED Light Tuya App for Alexa Google
$28.04
Color: R9 Remote
Please kindly note :
1.The remote control and LED controller in this link should be used with the same series brand,they can not be compatible with controllers of other brands.
2.For safe consideration,the package is not include batteries.
WZ-SPI ZigBee RGB/RGBW SPI LED Controller (Zigbee+RF 2.4G)
Compatible with up to 49 chips of RGB or RGBW led strips, with rich dynamic effects and can be painted segment color mixing. You can set the chip type and color order through the APP, or you can control it through the APP, remote control or third-party intelligent voice devices.
--Multi-pixel RGB/RGBW LED strip controller with SPI signal output, Tuya smart APP cloud control.
--Voice control, support for Amazon Alexa, Google Assistant.
--Compatible with RGB or RGBW LED strips with 49 kinds chip, the chip type and R/G/B/W color sequence can be set through the APP.
Compatible chips:TM1809(default), TM1804, TM1812, UCS1903, UCS1909, UCS1912, SK6813,UCS2903, UCS2909, UCS2912, WS2811, WS2812, WS2813, WS2815, SM16703P ,TM1803, TM1829, TLS3001, TLS3002, GW6205, MBI6120, TM1814B(RGBW), SK6812(RGBW), WS2813(RGBW), WS2814(RGBW), UCS8904B(RGBW), LPD6803, LPD1101, D705, UCS6909, UCS6912, LPD8803, LPD8806, WS2801, WS2803, P9813, SK9822, TM1914A, GS8206, GS8208, UCS2904, SM16804, SM16825, SM16714(RGBW), UCS2603, UCS5603, SM16714D, UCS7604(RGBW), UCS7804(RGBW).
--Painted segment color mixing: full color lling, color pencil segment painting, eraser segment light off.
--Rich dynamic effects: 44 default and 10+ custom dynamic scenarios, 16 variations.
--3 APP music rhythms.
--Match with RF 2.4G RGB remote control optional, such as R9.
WZ-SPI LED Controller Parameters:
--Input Voltage:5-24VDC
--Input Current:8A
--Input Signal:ZigBee+RF 2.4G
--Output Signal:SPI(TTL)x2
--Scenario Mode:44 default and 10+ customizations
--Pixel Dots:Max.1000
--Working Temperature:Ta:-30℃~+55℃
R9Ultrathin RGB/RGBW RF Remote Controller
This ultrathin remote can be paired with a WZ-SPI controller, and you can set the SPI LED strip length, chip type, and rgb color order with R9
---Apply to RGB or RGBW LED controller.
---Each remote can match one or more receiver.
---CR2032 battery powered.
---Operate with LED indicator light.
Parameters:
--Output Signal:RF(2.4GHz)
--Working Voltage:3VDC(CR2023)
--Working Current:<5mA
--Standby Current:<2
μA
--Remote Distance:30m(barrier-free space)
Package Include:
According your choose:
1x WZ-SPI LED controller
or
1x R9 Remote
