Tuya Zigbee Temperature Humidity Moisture Detector Smart Soil Tester Moisture Sensor Phone App Realtime Monitor for Home Garden
$43.55
Color: Type1
Description:
1) Zigbee Hub Required: Stardard zigbee 3.0 Version works with home assistant only.advice to use zigbee2mqtt ,not ZHA to get fully features.Tuya zigbee version can work with tuya zigbee hub and home assistant.
2)Waterproof:IPX4:the soil moisture sensor features an IPX4 waterproof rating for outdoor & garden use.
3)App Remote Control: Stay connected to your garden from anywhere in the world. Check your soil's temperature and humidity right from your smart phone.
4) Water Shortage Warning: Our smart system will gently remind you when it's time to water your plants, helping you keep your green friends happy and healthy.
5) Smart Monitoring: Keep track of air temperature, soil moisture,light intensity, so you always know what's happening in your garden.
6) Comprehensive Measurement Range: Our sensor accurately measures soil moisture from 0% to 100%, giving you complete insight into your plants' hydration needs.
7) User-Friendly Design: Compact, lightweight, and incredibly easy to use. Just plug it in and you're ready to go. With low power consumption, the batteries last a long time - making it the perfect companion for your garden care.
Product Specifications:
- Product Name: Soil Moisture Sensor
- Wireless Protocol: Zigbee 3.0 (requires Zigbee hub to operate)
- Soil Moisture Range: 0%-100%
- Temperature Resolution: 0.1℃
- Humidity Resolution: 3%
- Air Temperature range:-20~60°C
- lluminance range:0~150000 1x
- Temperature Measurement Accuracy: ±0.5℃
- Humidity Measurement Accuracy: ±5%
- Battery Type: LR03AAA Battery *1pcs (not included)
- Working Voltage: DC1.5V
- Standby Current: ≤20uA
- Standby Time: ≥12 months
- Temperature Unit Conversion: ℃-℉
- Working Temperature: -10℃-55℃
- Working Humidity: Max 99% RH
Package Contents:
- Soil Moisture Tester *1 (batteries not included)
- User Manual *1
