Tuya Zigbee Temperature Humidity Sensor Smart LCD Digital Thermometer Hygrometer Works with Smart Life Zigbee 2mqtt Alexa Google
  • Zigbee Connectivity: Reliable, low-power communication ensures efficient data transmission to your smart home hub
  • Smart LCD Digital Thermometer and Hygrometer Display: High-definition LCD for easy monitoring of environmental conditions
  • Wide Compatibility: Works with Alexa, Google Home, Zigbee2MQTT, and other platforms for enhanced automation
  • Compact and Elegant Design: Blends seamlessly into any home or office environment
Monitor your environment with precision using the Tuya Zigbee Temperature and Humidity Sensor. Designed for seamless integration into smart homes, this device provides real-time tracking of temperature and humidity levels via the Tuya or Smart Life app. Equipped with a Smart LCD Digital Hygrometer and thermometer, it offers an intuitive, high-contrast display for quick readings.
  • Zigbee Connectivity: Reliable, low-power communication ensures efficient data transmission to your smart home hub.
  • Smart LCD Digital Thermometer and Hygrometer Display: High-definition LCD for easy monitoring of environmental conditions.
  • Wide Compatibility: Works with Alexa, Google Home, Zigbee2MQTT, and other platforms for enhanced automation.
  • Compact and Elegant Design: Blends seamlessly into any home or office environment.
  1. Real-Time Alerts: Stay informed with instant notifications of temperature or humidity changes on your smartphone.
  2. Energy Efficient: Zigbee protocol ensures low power consumption, extending battery life.
  3. Custom Automation: Create routines like activating a humidifier when humidity drops below a set level or turning on fans during high temperatures.
  4. Historical Data Tracking: Access past environmental data for trend analysis and informed adjustments to your indoor climate.
How to Use
  • Pair the device with your Zigbee gateway for easy setup.
  • Monitor data and control connected appliances directly from your app.
  • Set triggers or scenes to automate temperature and humidity adjustments in your smart ecosystem.
Whether you’re optimizing plant growth, preserving valuable items, or simply maintaining a comfortable living space, this Smart LCD Digital Thermometer is a must-have for a modern smart home. Embrace efficient home automation and elevate your control with this advanced monitoring solution.
