Tuya Zigbee Water Sensor Leak Flood Detector Alarm Smart Life Work with Tuya Gateway Alexa Google Assistant for Kitchen Bathroom
Notice: 1. First you need to connect the Tuya ZIGBEE 3.0 gateway in order to remote control from your mobile phone via 3G/4G/ 2.4G WiFi. And the Tuya Zigbee Alarm also only works with the Tuya Zigbee gateway.
2. Please remove the plastic film of the battery inside of the water sensor, before you test it.
Description:
【Ultra-long battery life, low battery reminder】Low power consumption technology. The use of high-performance, low-power microprocessor, battery life of up to 1 year, to avoid frequent battery replacement (if the daily reminder of 20 times), the battery power is too low to send timely alarm notification.
Specification:
Communication mode: zigbee 3.0
Supply voltage: DC3V (CR2032 battery, included)
Material: Fireproof PC + fireproof ABS
System support: lOS8.0/Android4.0 and above
Application Name: Smart Life/TUYA
Operating frequency: 2.4GHz
Wireless technology: Zigbee 3.0
Wireless Distance: Indoor 30~50 metres
Operating temperature: -10℃~50
Packing list: 1 sensor, 1 manual (battery included)
