Tuya Zigbee/Wifi Outdoor Temperature Humidity Sensor Thermometer Smart Life Work Google Assistant ,IP65 Waterproof+Hanging Rope
Must-read before buying
1,If you plan to place the device in a refrigerator, please switch to low-temperature-resistant batteries.
2,For any shipping issues or product defects, reach out to me first and I’ll take care of it.
NOTE:
About Zigbee Version
The Zigbee Version—you’ll need a Zigbee gateway to use it (Zigbee2MQTT is not supported at the moment).
About WiFi Version
The WiFi Version—This device can connect directly to your router(Requires a 2.4 GHz Wi-Fi network)
1. Battery powered, designed to save power, sensors are not always connected to the network . It will sleep to save power.
2. When the temperature change exceeds ±0.5℃ or the humidity exceeds ±5%RH, it will connect to network, begin send data to the server.
3. The sensor connects to network at least once an hour and reports data once.
APP Pages
Product Features:
1. High precision.
The sensor uses top suppliers. It can guarantee the high precision of the measurement data.
2. App monitoring and recording.
The sensor will monitor the temperature and humidity in APP. You can view the changes in the value on the APP.Record the temperature and humidity changes on the APP, and use the graphics to show you.
3. Scene linkage.
The sensor can be used as the temperature and humidity data source of Tuya Smart, Smart Life, Amazon Alexa, Google Home. You can do many automated processes based on the data source.
4. Third-party voice support.
The sensor supports Amazon Alexa, Google Home Assistant. You can check the current temperature and humidity by voice.
