weBoost Home MultiRoom 4G Cellular Signal Booster Kit, Medium-Size Home
$569.99
Say goodbye to dropped calls and slow data speeds with the weBoost Home MultiRoom 4G Cellular Signal Booster Kit, designed for medium-sized homes. This powerful booster kit enhances your cellular signal across all carriers, providing better voice quality, faster downloads and uploads, and a more reliable connection. With its sleek and modern design, the weBoost Home MultiRoom blends seamlessly into any home decor, and its easy DIY installation means you can start enjoying improved cell coverage in no time. Don't miss important calls or messages - upgrade your home with the weBoost Home MultiRoom 4G Cellular Signal Booster Kit today!
Manufacturer Part #: 470144
UPC: 810005961288
Frequencies - Band 12/17: 700 MHz
Frequencies - Band 13: 700 MHz
Frequencies - Band 5: 850 MHz
Frequencies - Band 4: 1700/2100 MHz
Frequencies - Band 25/2: 1900 MHz
Max Gain: 65 dB
Impedance: 75 Ohm
Connectors: F-Female
Booster Dimensions: 6 x 6 x 1.6 inches
Booster Weight: 1.9 lbs.
Certifications: FCC
Warranty: 2 Years
