Wifi Smart Wall Light Switch Work with Apple Homekit Alexa Google Home EU US 110V 220V, Power Consumption, LCD Touch Screen
Regular price $119.81
Regular price $119.81 Sale price
  • Hign-concerned Chemical: None
  • Communication method: Wi-Fi
  • Camera Equipped: No
  • State of Assembly: Ready-to-Go
  • Model Number: LANBON
  • Compatibility: All Compatible
  • Brand Name: weten
  • Origin: Mainland China
  • Certification: CE,FCC
  • Current: 10A
  • Voltage: 100V-250V
  • Rated Load: 200W
  • Wifi Standard: 2.4GHz, 802.11 b/g/n
  • Warranty: 1 Year
LCD Touch Screen
The Smart Light Switch has LCD touch screen functionality to show more information and allow customisation. The screen shows information such as Time, Power consumption, and even an epidemic report. You can customise the switch icon, name, and overall theme to your preference.
5 in 1 Switch
The Smart Light Switch can be used as either one of 5 different switches:
  • 1 gang
  • 2 gang
  • 3 gang
  • Curtain switch
  • Scene switch
NO Hub Required
This switch can be connected with wifi router direcely, not need Hub / Gateway / Bridge.
App Control
Anytime anywhere, control the Smart Light Switch through Apple Homekit App
Voice Control
Control the Smart Light Switch through your voice with Google Home, Alexa Echo and Siri.
Power Comsumption
You can check real time power consumption and summarized power consumption.
Delay & Timmer function
Set a delay to turn lights on/off after a specified time. Schedule lights to turn on/off during your preferred time of day.
Vertical or Horizontal installation
You can choose the screen to display in vertical or horizontal according to personal preference.
Standby Mode & Night Mode
To save energy, the switch turns to standby mode automatically with the screen light dimmed to the setting level. In the Night Mode, the LED backlight around the frame will be turned off.
Attention
1. Neutral wire is requird for this switch, pls make sure your house has neutral wire.
2. This switch is only for Apple iphone or ipad, support Apple Homekit App and Siri Voice Control.
3. This switch isn't compatiable with Android phone, don't support HOME ASSISTANT.
>>> If you need Android Version or Home Assistant Compatiable Version, pls contact us <<<
