Winland WaterBug 350 System
$168.95
  • Immediate Alerts: The WaterBug 350 System instantly alerts you through built-in alarms and LED lights when water is detected
  • Compact and Powerful Sensor: Detects even the slightest amounts of water to prevent potential damage
  • Easy Installation: User-friendly interface allows for quick and easy setup in minutes
  • Customizable: Compatible with various accessories, including additional sensors and automatic shut-off valves, to tailor the system to your specific needs
  • Reliable Protection: Provides peace of mind by ensuring any water leaks are detected early, protecting your property and belongings
Shop Winland WaterBug 350 System
The Winland WaterBug 350 System is the ultimate solution for monitoring and alerting you about water leaks in your home or office. This advanced system comes with a compact and powerful sensor that can detect even the slightest amounts of water and alert you immediately through its built-in alarm and LED lights. With easy installation and a user-friendly interface, the WaterBug 350 System can be set up in minutes and provide you with peace of mind knowing that any potential water damage will be detected before it becomes a major problem. The system is also compatible with various accessories, such as additional sensors and automatic shut-off valves, allowing you to customize the system to your specific needs. Protect your property and belongings with the Winland WaterBug 350 System today.
Key Features:
  • Immediate Alerts: The WaterBug 350 System instantly alerts you through built-in alarms and LED lights when water is detected.
  • Compact and Powerful Sensor: Detects even the slightest amounts of water to prevent potential damage.
  • Easy Installation: User-friendly interface allows for quick and easy setup in minutes.
  • Customizable: Compatible with various accessories, including additional sensors and automatic shut-off valves, to tailor the system to your specific needs.
  • Reliable Protection: Provides peace of mind by ensuring any water leaks are detected early, protecting your property and belongings.
Safeguard your home or office with the Winland WaterBug 350 System, the reliable and effective solution for water leak detection and alerting.
Product Specs:
Console Size 5" x 2.44" x 1.25" (12.7 cm x 6.2 cm x 3.18 cm)
Probe Size (Standard P/N #1040) 2" x 3" x 0.88" (5.1 cm x 7.6 cm x 2.2 cm)
Probe Size (Under Carpet P/N #1041) 2" x 3" x 0.18" (5.1 cm x 7.6 cm x 0.5 cm)
Power Requirements (Resting State) 9V battery @ 1.8 microamps
Power Requirements (Alarm Condition) 9V battery @ 380 microamps
Approximate Battery Life 1 Year
Sensitivity Will not alarm due to high humidity or condensation
Operating Temperature Control and Probe: 32° to +140° F (0° to +60° C)
Outputs Open collector max. to tripline- 30VDC
Recommended Dist. Between Probes and Console 1-2 probes: 200ft (61 m) max.
3 or more probes: 100ft (30.5 m) per probe
Recommended Max. Probes Per Console 6
