X10 Appliance Wall Switch
The X10 Appliance Wall Switch is a must-have device for anyone looking to automate their home appliances. This wall switch allows you to control your appliances remotely, using X10 technology. With the X10 Appliance Wall Switch, you can turn on/off your appliances, set timers, and even dim the lights, all from the comfort of your couch or bed.
Installation is quick and easy, requiring only a screwdriver and a few minutes of your time. Once installed, the X10 Appliance Wall Switch is ready to use with any X10 remote control, making it a versatile and convenient addition to your home automation system.
The sleek design of the switch blends seamlessly with any decor, making it a stylish and functional addition to any room. Whether you want to turn on the coffee maker in the morning or dim the lights for movie night, the X10 Appliance Wall Switch is the perfect solution for your home automation needs.
Product Specs:
AC Voltage 120 VAC, 60 Hz
Load Rating 1800 Watts, 1/2 HP, 20 Amps
Dimmable No
Connection Requirement Neutral Wire
Certifications CSA approved
