Shop X10 Companion Wall Switch for 3-Way Application With Seamless Multi-Location Lighting
The X10 Companion Wall Switch for 3-Way Applications is an essential addition to your smart home lighting system. Designed to work with X10 master switches, this 3-way switch enables seamless control of a single light from multiple locations, making it ideal for staircases, hallways, and large rooms. Whether you’re looking to enhance convenience or expand your automation system, this switch is a perfect solution.
Versatile Compatibility: Works with X10 master switches like WS12A, WS13A, XPD3, XPS4, and XPDI3 to create a 3-Way Applications Switch setup.
Elegant Design: Comes with interchangeable white and ivory paddles to match your home’s décor
Reliable Control: Provides local on/off functionality, and when paired with dimmable X10 master switches, allows precise brightness adjustments.
The X10 Appliance Wall Switch is designed for 3-way switch configurations, allowing control of a single light from two locations. Simply replace one of your existing switches with an X10 master switch and the other with this companion switch to enjoy enhanced accessibility.
Convenient Multi-Location Control: Operate lights from different areas using this 3-Way Applications Switch.
Seamless Integration: Works effortlessly with X10 home automation systems without requiring complex wiring.
Aesthetic Appeal: Customizable paddle covers ensure the switch blends with your home’s design.
Upgrade your home automation with the X10 Appliance Wall Switch, a reliable and stylish 3-way switch solution that enhances convenience and efficiency.
