X10 Deluxe Wireless Base Transceiver Module
$30.95
Integrated Appliance Control: Equipped with a built-in appliance module, the transceiver allows direct control of connected devices, eliminating the need for additiona..
Effortless Installation: Simply plug the transceiver into any standard wall outlet to establish communication between your X10 remotes and modules, streamlining the se..
Comprehensive System Integration: The transceiver manages up to 16 X10 receivers per house code, facilitating extensive automation setups
The X10 Deluxe Wireless Base Transceiver Module is a pivotal component in home automation, enabling seamless control of your household devices. By receiving radio frequency (RF) signals from X10 wireless remotes, it converts them into X10 commands transmitted through your home's electrical wiring, allowing centralized management of various appliances and lighting systems.
- Integrated Appliance Control: Equipped with a built-in appliance module, the transceiver allows direct control of connected devices, eliminating the need for additional modules.
- Effortless Installation: Simply plug the transceiver into any standard wall outlet to establish communication between your X10 remotes and modules, streamlining the setup process.
- Comprehensive System Integration: The transceiver manages up to 16 X10 receivers per house code, facilitating extensive automation setups.
Incorporating the X10 Deluxe Transceiver Module into your home automation system enhances convenience and efficiency. Control lighting, appliances, and other devices remotely using compatible X10 remotes, creating a personalized and responsive living environment. The module's ability to transmit signals over existing electrical wiring reduces the need for additional cabling, simplifying installation and minimizing clutter.
By integrating the X10 Wireless Base Module, you can customize your home's automation to suit your lifestyle, ensuring comfort and energy efficiency. Whether you're looking to remotely manage lighting, control appliances, or expand your existing X10 system, this transceiver module offers a reliable and user-friendly solution.
