X10 Plug-In Appliance Module, 2 Prong
$23.95
  • Easy Installation: No complex wiring is required; plug the module into an outlet and connect your appliance
  • Compatibility: Works seamlessly with a variety of X10 controllers, allowing centralized control of your devices
  • Enhanced Home Security: Integrate with X10 motion sensors to activate appliances automatically, deterring potential intruders
The X10 Plug-In Appliance Module (2-Prong) is a versatile device that enables remote control of your household appliances through the X10 home automation system. By simply plugging this module into a standard wall outlet and connecting your appliance, you can effortlessly manage devices such as lamps, radios, or fans from anywhere in your home.
  • Easy Installation: No complex wiring is required; plug the module into an outlet and connect your appliance.
  • Compatibility: Works seamlessly with a variety of X10 controllers, allowing centralized control of your devices.
  • Enhanced Home Security: Integrate with X10 motion sensors to activate appliances automatically, deterring potential intruders.
Incorporate the X10 Plug-In Appliance Module into your home automation setup to control devices remotely. For instance, pair it with an X10 Companion Wall Switch to manage lighting fixtures from multiple locations. Alternatively, use an X10 Wall Switch to operate ceiling lights, while the appliance module handles plug-in devices.
  • Convenience: Turn appliances on or off without being physically present, enhancing daily life efficiency.
  • Energy Savings: Schedule devices to operate only when needed, reducing unnecessary power consumption.
  • Safety: Automate lights and appliances to create the appearance of an occupied home, enhancing security.
For expanded control, consider integrating the module with an X10 Companion Switch, enabling multi-way control of your devices. This setup allows for flexible management of appliances from various locations within your home.
