X10 Plug-In Appliance Module, 3 Prong
$23.95
Controlled Power to Any 3-Pronged Device
The X10 Plug-In Appliance Module is a versatile and efficient device that allows you to remotely control the power to any 3-pronged appliance or electronic device in your home. With its simple plug-and-play design, you can easily install the module and start controlling your devices from anywhere in your home.
This appliance module is compatible with X10 home automation systems and can be controlled using a variety of X10 controllers, including remote controls, wall switches, and smartphone apps. You can also set up timers, schedules, and scenes to automate your devices and make your home more energy-efficient.
With a maximum load capacity of 15 amps, this appliance module can handle even high-powered devices like air conditioners, heaters, and refrigerators. And with its compact design, it won't block adjacent outlets or take up too much space in your home.
Overall, the X10 Plug-In Appliance Module is a reliable and convenient way to control your home's appliances and electronics. Whether you're looking to save energy, improve convenience, or enhance your home automation system, this module is a great choice.
