X10 PRO 1-Button Keypad (1-Address), White
Regular price $11.95
Regular price $11.95 Sale price
Shop X10 PRO 1-Button Keypad Wall-Mounted Controller With Simplify Your Home Automation
The X10 PRO 1-Button Keypad is a versatile wall-mounted controller designed to provide seamless ON/OFF control for any X10 PRO device sharing the same House and Unit code as the XPT Base Transmitter. This single rocker switch is an ideal solution for simplifying your home automation system.
  • Single-Button Control: Effortlessly manage one X10 address with a straightforward rocker switch, ensuring user-friendly operation.
  • Customizable Keypad: The keypad cover attaches easily to the XPT Base Transmitter, allowing for quick installation and a clean appearance.
  • Standard Installation: Designed to fit into a standard single-gang wall box, making it convenient for most home setups.
To install, connect the XPT Base Unit to the HOT and Neutral wires in your existing wall switch box. Once secured, attach the X10 PRO 1-Button Keypad by inserting the top tab under the notch of the XPT Base and pressing firmly until the pins connect. This setup enables ON/OFF control of any X10 PRO device configured to the same House and Unit code. It's important to note that the XPT, combined with the keypad, functions solely as a transmitter and does not directly switch electrical loads.
  • Enhanced Convenience: Simplify your lighting and appliance control with a dedicated wall-mounted controller.
  • Flexible Integration: Easily incorporate into existing X10 home automation systems without the need for additional wiring.
  • Streamlined Design: The sleek appearance of the X10 PRO 1-Address Keypad complements any interior dĂŠcor.
By utilizing the X10 PRO 1-Button Keypad, you can achieve efficient and centralized control over your home devices, enhancing both functionality and aesthetic appeal.
